Originally Posted by 4rociousrunner
I mean, i'm only running 32s at this point and no beadlocks, so the lowest i ever dare to go on the Falkens is around 24 PSI on the trails. That being said, I DON'T do any rock crawling at this point since I'm only on 4600s and 1.5" of lift; I can't afford a fully fledged build at this point being a college student . The rattling in the steering wheel is awful even at a low psi on something as simple as a forest service road.
Are those e rated tires? If so you’ll need to go down more. 24 is not low enough imo to do any good. I always go alittle above 15. You won’t have to worry about blowing a bead. Especially if you aren’t rock crawling
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
