Originally Posted by jhguth
I need to hit mine, same grease on all joints?
(SEE EDIT BELOW)No, per the manual. Moly fortified on slip joints, regular GL on spiders. The manual tells you the two types needed. I got mine from Amsoil, but there is a good bit of diversity on the forum of what grease is best.
Edit to what I posted above since it was pointed out that it is not correct. In the manual, it lists NLGI2 chassis grease for the spiders and moly-fortified OR NLGI2 for the slips. Somewhere on here someone explains why moly-fortified is better for the slips and why you should not use moly-fortified on the spiders, but per the manual, regular NLGI2 is OK for both. Godd luck!
