Originally Posted by Wedgy
Update..... Suddenly it works... like nothing ever happened. I was about to take the park/neutral safety switch out and mess with it, I put the relay back in and it works. I had the relay out so I could jump it by connecting the 3 to the 5 pin to start it. My relay worked in my 1997 4runner and the 1997 relay would not work in my 1998 so it isn't the relay. I was getting slightly less voltage to the #1 pin when the key was turned, not enough to trigger the relay. Down for 9 days... I'll mess with it when I get a chance but for now I'm blaming global warming
Any major temperature change in your area? I am glad it works but if you didn't find the cause it may do it again.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
