Originally Posted by joshik
I got my 2 washers today and installed them after the kiddos went to bed. Took about 30mins-ish per side but took longer because I had to replace the driverside ABS/speed wire. I also took time to bend open the brackets and adjust the wire so that the brackets could mount using the default hole and I could freely adjust the wire so it would not bend too sharp or be too tight.
So after I installed the 2nd washer it looked better. But after I went for a drive I guess it magically seated itself and looks great!
Nice! Looks like the washers did the trick! Now if only Marlin would text me back...
