Originally posted by drmorbius
There is a thing that looks like a metal bottle called a receiver/dryer which has a sight glass in the top and is usually mounted somewhere near the A/C heat exchanger(radiator). There may be a rubber cap over the sight glass which just pulls off. You should see flow across the sight glass but if you see bubbles it means you have lost some of your charge. Hope this helps.
Can u post a pic where this is at?
