ElectroBoy
Banned
Installed a Smittybuilt model 2763 Storage Vault today...
What do you all do to keep your turnbuckles snug?
Mine always loosen up after a while of driving around.
Is there a locknut method, or to use locktite, or ??
Is that t track aluminium?My homemade version
Looking great! Glad it looks like everything fit in the drawerLike many of you, I have sought out to level out the back of the 4Runner using a simple sheet of plywood on some runners. I also wanted to add some storage to it while maintaining room to sleep in and didn't want to lose too much space, so behold the pictures below! Full disclosure: I do not have the time, skill, or resources to build this myself so I paid a pretty penny to have it done. It is based on and built by the same guy who did this: Building a 5th Gen (2010+) 4Runner Storage Platform – ADVENTURE TACO with a custom twist.
The drawer uses these: Firgelli Automations Full Extension Ball Bearing Drawer Slides 400 lb Capacity (36 Inch) - - Amazon.com
Looking great! Glad it looks like everything fit in the drawer![]()
You can tie wrap one end. That's enough to stop rotation
Mark, If that's a picture of your turn buckles you might want to get a heavier type. Look closely at the number of threads and the size of the screw. This type of cheap metal buckle will strip out and fail in an accident or rollover.
I use a Larger turn buckle and don't have this problem.
Get a larger turn buckle and if the problem continues use a lock washer and a nut on both sides of the buckle. or get a NYLOC nut on both sides.
