Originally Posted by Crackership
Well, I think I figured it out. Here's the compression numbers:
1: 165
2: 30
3: 160
4: 155
5: 170
6: 160
You'll notice one of those numbers falls outside the acceptable tolerance by a little.
So, where do you all suggest sourcing an engine from?
Oh dear 30 is not going to fire. At least you found the cause.
If fluid levels arent dropping could be either valves or rings on that cylinder. Or a cracked head.
Engines are readily available. Just like transmissions etc.
The rest if the engine is good. I suspect head or valves not sealing.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
