View Single Post
Old 07-11-2020, 10:05 AM
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute
JZiggy's Avatar
Originally Posted by TheDurk View Post
The PWR relay, unfortunately, is not so convenient. It's on the reverse side of the fuse panel by the driver's knee on the top right corner, so accessing it to swap in a jumper is sort of a pain. You have to pull the panel. The best way would be to wire an always-on 12V+ source through a switch and connect that to Terminal 1 of the relay. That would allow you to energize the system as needed. Either tap a fused circuit like the DOME circuit or use an inline fuse. Relay coils don't use much so 1 amp is plenty.
The key chime, if memory serves, is soldered into the gauge cluster. Best way to deal with it is a fatal injection of superglue.
I also want to allow the power passenger windows to be able to operate without the key to allow adjustments during camping, etc. A couple questions:
- If I wire in a switch to put 12V at terminal 1 to energize the relay would I need to add a diode to that it doesn't energize terminal 2 of the ECU?
- I thought about simply jumping terminals 3 and 5 of the PWR window relay. I realize due to its location it is not convenient to reverse this so it would need to be considered semi-permanent. What are the consequences of just bypassing the relay? Is it possible for this to run down the battery somehow?
JZiggy is offline   Reply With QuoteReply With Quote
