Originally Posted by Currie_1
@That_Titanium_4RNR I'm looking to do a very similar set up as you with the 285/75/17's. I'm going to go Icon stage 2 , Icon Delta joint UCAs with a BMC and obviously and a lot of cutting on the fender wells lol. 0 offset fifteen52's and have spidertrax if need be. What size bump stop extensions are you running ? I see that there are a few different ones that metal tech offer. Also before your body mount relocation were you still running into big issues with the mount at full stuff?
I'm currently not running any bumpstop extensions, but I really need to add some in the front especially. Thinking durobumps are what Ill use.
And yes, before the BMR there was scrubbing in the rear. But I helped fix alot of that by using my LCAs in conjunction with my SPC UCAs to gain maximum wheel clearance in the rear of the wheel well area.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
