Originally Posted by sleepydad
as long as it's still functioning I would leave it alone.
if the radiator is still original I would replace it.
there are some other items on these truck that tend to cause issues after 20+ years. lower ball joints, radiator, rear axle seals.
almost anybody can do a radiator replacement, it's super easy. protects you from overheating and doing engine damage.
2,Cents
Thanks! Actually my radiator cracked over a year ago and was replaced. Gotta timing belt change too. The stealership said the water pump was fine and didn’t need replacing. I know the old saying “if it’s not broke don’t fix it”. But this truck is old and I’m just trying to stay ahead of things.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
