Thread: Fluid Capacity
View Single Post
Old 09-28-2020, 04:30 PM
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Originally Posted by fkheath View Post
The transmissions, differentials, transfer case, etc are now considered life time fill from the factory under normal operating conditions. Thus, you have many, many years, perhaps a decade or more before you will need to replace those fluids. So, I guess my question is why ask for a new 4Runner?
Well that's just not true.
https://www.toyota.com/t3Portal/docu...-204Runner.pdf
"Front and Rear Differential Oil
Inspect or replace at specified intervals.
When performing inspections, check each
component for signs of leakage. If you
discover any leakage, have it repaired by a
qualified technician immediately"
"SERVICE INTERVALS (AS RECOMMENDED BY TOYOTA):
Differentials: 15,000 miles when heavily loaded, or with roof-mounted gear
Transfer case: 30,000 miles when driving dirty or dusty roads"
ATF: 90,000 miles
Toyota recommends that under “standard conditions” fluids be replaced as needed based on levels and color.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
