I should elaborate, it was stuck on AC cold fans high every morning in cold weather ironically when you first started it, the fan dial was sketchy and jumpy but would dial down/turn off, AC could be turned off, and after it warmed up temp dial would become responsive, which sucks in -30 we get. This wasn't my vehicle, it was filthy behind the dash, dust everywhere where as mine looks like new under the dash and I'm still in the original Climate control FWIW.
