I did a search on Tacomaworld.com and the answer was yes, they are the same. Toyota hasn't changed the front suspension for a while. It's a good design and works well.
Looks like the only difference on the 3rd gen Tacoma is the LCA which has a large rear cam bolt. Not sure if our 4th gens have that as well or if that is a 5th gen difference.
only suspension component that cant be swapped between 2nd gen and 3rd gen is the LCA due to the larger (dual vvti 4.0L FJ/4runner style) rear cam bolt. Everything else can be swapped.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
