Originally Posted by LandCruiser
The motor is supposed to torque on the mounts and even make the truck sway a bit under throttle but it shouldn't wobble back and forth after that.
Originally Posted by flyrv9
Agreed - the motor should move a little from the torque and play in the rubber in the mount. But it should not lift up. I'd think a broken mount would be a rare occurence usually caused by a rather large jolt - like a big pot hole.
In looking at the construction of the assembly, it's possible that one of the mount bolts could break, be loose, or the insulator could wear or break? I would inspect those mounts and insulators carefully to rule them out. OP says he hears a noise and feels vibration when idling/revving. I think mount is possible, hopefully not engine issue.
