Thread: Starting issues
View Single Post
Old 12-26-2020, 09:56 AM
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Being your throughly went through the fuel system and looks like you covered the ignition system.
Happens only when hot. Is making me wonder.
The fluid levels not changing like you not loosing antifreeze?
Compression good?
I wondering if your having a crank sensor or maf or anything of the ignition electrical side tasting good but still intermittently failing with it gets hot.
Did they check all these components when the engine is at operating temperatures.
Being it's not just dying going down the road and your are fine till restart or start. It almost has to be something involved in the starting process itself. Sorta would eliminate the crank and maf sensor.
Unless you have one heck of a vacuum leak when the engine is warm. That would make it hard to start as well.
How's all the vaccuum hoses looking? PCV value not stuck open?
I just trying to come up with ideas for you at this point. As I see you been working on the the rig for quite sometime.
