View Single Post
Old 01-24-2021, 02:05 PM
MIKE969 MIKE969 is offline
MIKE969 will become famous soon enough
Tacoma and 4Runner swap wheels? 17x8 0mm offset and 275/70/17 BFGs
The TRDOR Tacoma has 16” wheels which won’t fit on your 4runner. You will most likely need to put the stock wheels back on the 4R if you want to move the LVL8s to the taco.
Your level8 wheels and 275’s will probably rub on a stock suspension setup on the taco. They will most likely require trimming and possibly CMC too.
You should check out the Tacoma forums to see what it takes to fit 275’s. TPMS probably won’t be compatible either, but you could always just have them swapped over to the new wheels.
2021 TRDORP/KDSS
OEM Pro Grille, Fifteen52 Turbomac HD Graphite (17x8.5 ET 0), Falken Wildpeak AT3W 265/70 SL.
MIKE969 is offline   Reply With QuoteReply With Quote
