I looked into this years ago but never pulled the trigger as the Budbuilt stuff was looking pretty good. From what I understand that will work for the non fat lip 4R with the Tacoma mounting brackets as it wasn't an option for a early 3rd gen, the 99-02 fat lip will need to use the 02 sport edition version pz327-35010 and mount brackets.
