had a similar issue with my sc300. troubleshooted for a month, tried everything (i.e. tune up, clean the maf, check fuel pump, check relays, check vacuum leak). on a longshot, we finally decided to swap out the ecu and the car worked fine. we diagnosed the ecu and found out hte fuel module on the ecu had burnt out and need to be replaced. if you tried all other options, you may want to consider this. hope this helps.
2000 4Runner SR5 V6, 5-spd, 4WD
TRD Supercharger, URD 7th Injector kit, 2.2 URD pulley, Walboro fuel pump, 3" OME supesion, deck plate mod, 6K HID, red city lights, Alpine DVD player w/ 5 ch digital theatre amp  TS, Dolby Digital, Alpine center channel, 12" Pioneer sub w/ 400W Xtant amp
2006 Lexus IS350
