Looking to place an order soon. I have a 2WD V6 2008 and I just want to make sure I order the right things. I'm looking to get about a 2.5" lift in the front and 2" lift in the rear. I want it level or a smaller factory rake still. I'm thinking of ordering:
Front Coil: C59-302 - V6 - Stock front end load, 2.5" lift. 395/395mm, 17mm wire, 586LB
Front Strut: IMS59-50220 - IMS Front Monotube Struts - suit 0-3.5" lift
Rear Coil: C59-325 - Stock rear end load, 1.75" to 2" lift. 420/420mm, 17mm wire, 220LB
Rear Shock: IMS59-50705 - IMS Rear Shocks comfort valved - suits 0-3" lift
Some questions:
- I have factory weight, so I'm assuming the comfort valved rears will be more enjoyable? Better for rough roads and speed bumps?
- Will I need new UCAs at the 2.5" front coil lift? (No offroading)
- If stock UCAs, what camber do I need for proper alignment?
- Do I need the top mounts too? Or anything else I'm missing?
- Are these "serviceable" shocks that recommend having them sent to the factory for refurbishing every 40k miles or so like I've seen on others? Or set it and forget it?
