Originally Posted by Bry n
Need tips cleaning this up �� I obviously suck at sanding it’s actually my first time sanding plastic in hard to reach areas. Also wondering what I can use to help clean out the little tight corners. Had a hard time reaching deep into the corners cause the collet/chuck would end up eating into the plastic if I got any closer. I was using a harbor freight special rotary tool with a lackluster bit kit lol. The white stuff is lubricant I didn’t fully clean off yet
You should be able to clean a lot of it up with a utility knife. Then you could use a small half round rough file and or wrap it with some 120 or 60 grit sandpaper….
Or wrap a paint stirring stick with sandpaper.
Use your imagination, it shouldn’t be that hard!
Let us know.
