Thread: tbu surprise
View Single Post
Old 07-03-2021, 05:16 AM
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
the 1999-2006 Tundra has only one brake rotor size. However, the earlier 199mm calipers were updated to the bigger 231mm calipers and bigger brake pads but rotor size remained the same.
Originally Posted by brillo_76 View Post
Which of the TBU calipers does your Hilander have? If I am not mistaken there are 2 types. Ones that are the same size rotor except the rotors are wider. Or the ones that require the 17 inch wheels with the larger rotor diameters.
Anyways, if you have leaking wheel cylinders. I change those and bleed the system well. Then adjust the back brake shoes up. Might just fix up your softer pedal.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
