Originally Posted by anomalous
Anyone else here using Victory 4x4 rear diff skid on their 5th Gen 4Runner ? I tried to install last night, but was having issues with the axle brackets not fitting right, and I felt the rear bolts on the axle brackets were riding a little too tight against the hard brake lines. When I was able to get all 4 nuts\bolts on for the axle brackets, I found that the front bracket that goes around the front of the third member, and the skid plate wasn't sitting flush onto each other. Starting becoming a real pain in the ass, so I aborted the install for now. Wondering if anyone else using this skid had issues installing. Thanks !
Damn video makes it look like it's so easy. Haha
4Runner Rear Diff Skid | 5th Gen (10+) - Victory 4x4
Did you assemble it all with the nuts loose? Front upper bracket is in front of the lower one?
For the hard line, I see in the video they disconnected the bracket on the axle and had it out of the way. Are you saying it pushes against the axle bracket when you reinstall it? With hard line you can carefully bend it a little to modify its routing and/or slip some rubber hose around where it makes contact with the brackets.
