View Single Post
Old 11-03-2021, 08:43 PM
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Originally Posted by jayw View Post
I used the INJ 10a under the hood, but the add-a-fuse comes with a 15. That's 25a in serial as I understand, this seems inappropriate. I've heard to just use the 15a and pull the 10a, is that correct? I want to get the fuse right. thanks
How much amp draw is on your grill lights?
That’s the size of the fuse you need to protect that circuit. If you go higher, you are not protecting the circuit if it shorts.
Tap into the the made circuit side of a switched circuit and then protect your light circuit with only the amp draw rated fuse for the lights you are installing.
Does that make any sense?
Best Regards,
Saker
