Originally Posted by Rottwagon
Yakima Mighty Mounts 23H. They work perfectly on the stock crossbars. The rack tubes are 1.75" OD. Many clamps and mounts can be found to fit the tubes if you do a quick search. There will be a clamp solution for anything you want to mount to the tubes.
I see silver screws under the rotopax and through the Yakima mount. Where did you get the screws from or did they come with the Yakima mounts or Rotopax mount?
