View Single Post
Old 06-11-2022, 01:51 PM
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Originally Posted by Pyral View Post
There is a pin that slides between the pads and the rotors to keep them in place, could greasing that help?
I wouldn't recommend greasing the pin as much as I'd recommend simply replacing it if it's corroded. Why not grease? If you use conventional grease, the heat generated through braking will liquify the grease and let it run down onto your brake pads. As you might guess, that won't end well.
That said, Toyota does make a special grease for use on certain parts of a disk brake system. It resists heat very well. In the picture below, it's the product on the left. I'd still recommend new pins though.
Too Stroked is offline   Reply With QuoteReply With Quote
