Originally Posted by T4Rscott
I think I found a possible issue.
I went back to the FSM and looked up the ECM plug diagram. I proceeded to check everything to do with the AC.
AC switch off - 9-14v
AC switch on at idle 5v or more
Both tests were 0volts
The circuit it labeled ACT-E1. I wonder if that is actuation? I traced the wire blue/ yellow straight back to the amplifier.
I’m in the process of getting another ECM.
Pin 13 and Pin 25 off of the ECM goto your AC amplifier on the D connector.
13 should be a blue black wire.. 25 should be blue yellow wire
Which ac do you have the manual one ? or the automatic ? ( what does your dash controls look like? They levers or digital)
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
