That's what we did with my wife's '96 when installing the 4X Innovations bumper. The early style frame only had 1 (2?) small bolts on the end of the frame per side, the bumper also used those tow hook bolts underneath, but clearly was not getting much strength from those two small bolts. Since I was putting a bumper on my 99 at the same time, I took the crash bar off the '99 and used the mounting plates from it. Cut the end plates off her frame, cut the mounting plates off the crash bar, and welded them to the end of her frame. Now 3 large bolts on each side, gotta be stronger.
