Originally Posted by Chitwood
Thanks for all your work on this thread.
The brakes on my son's '08 Sport are not feeling good at all. Really strong shaking during the braking process and I plan on fixing it ASAP.
Correct me if I'm wrong but fixing the Sport won't necessarily be an upgrade since the 4th gen came with the larger rotors & calipers.
The only question I have, is do I need to change the calipers? How would I know for sure if they're shot or the problem is limited to warped rotors?
Part of me just thought I would order calipers, rotors, and pads but wouldn't mind saving $300 if the existing OEM calipers are still good.
Yes, the SE has the larger rotors so I don’t know how much of an upgrade 5th Gen brakes would be.
As for the calipers, my experience was that one or more pistons wouldn’t move when I tried to retract them. You could buy the calipers so you have them if needed then return them if not.
I just did my ‘07 Sport’s brakes with
OEM pads and rotors since Toyota’s online price was essentially the same as the aftermarket gear I was looking at. Couldn’t be happier.
