View Single Post
Old 03-10-2023, 04:17 PM
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Originally Posted by Bad Luck View Post
That might be something you would want to use a spare throttle body for. I've never disassembled mine completely or seen it done so there may some components that can't/shouldn't be removed. If you do decide to disassemble it I would video it, because I have terrible memory and will definitely forgot the order I took it apart in after it comes back from powder coating.
Agreed, I decided against fully disassembling the TB, that's just too scary. Here is how far I went:
I took a bunch of pictures to aid in reassembly, time will tell if it was enough:
I plan to take the metal parts to the plating shop, along with the other bolts and miscellaneous items that need to be replated:
I'm thinking of just hitting the TB body with some good direct to metal paint and calling it done.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
