View Single Post
Old 03-12-2023, 10:29 AM
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Originally Posted by Drew76 View Post
It's been about 5 yrs since I did that work but I think it was just dupli color adhesion promoter, I used some off the shelf clear from home depot and it has started to yellow a bit now. If i was to do it all over again i would use the VHT high temp gloss clear for brake calipers. I used that on my rear drums after painting them black and it has held up great. Those valve covers look clean. I did my valve covers and intake pipe with the VHT wrinkle Black paint but obviously powder coating is superior, I had a set of FJ wheels and Tacoma wheels refinished and powder coated and they came out great.
Thanks for the details! I wonder if I should skip the whole powder coat route, and the associated concerns about residual media/sand particles, and just hit them with some good primer and engine enamel. It'll probably be the 95% solution, without the aggravation. I rattle canned the entire AOR front bumper after all, and am still quite happy with the results.
And if it doesn't last, I can always do the powder coating later (the plenums are certainly easy enough to remove).
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
