Today I tackled one of the bigger projects I have "ready" to do, that was my rear charging panel for when I go camping.
The button housing is from a 2007 scion tC. I had originally planned it to be the full length, with the window controls being replaced with a voltmeter, but felt it was too long. Running the wire actually wasn't as bad as I thought it'd be, just a little tedious to remove all the interior panels and put them back, but it gave me something to do today.
The button on the left is actually from a 2001 Celica, which is supposed to be the window lock. I use it to interrupt the power to the rest of the panel so I don't need the ignition on for it to work.
Next to that is the 115v button and outlet, this time from a 2003 Matrix, and last but not least is a blank that I carefully drilled and dremeled out to accept USB.
Proud of how this turned out, it looks really clean and won't get in the way of my eventual sleeping platform.
Some other things I've done since the last update:
-Replaced Headlight Stalk with one with a fog light switch (super easy, just need to add two pins)
-added the OEM Volkswagen connector to my fuse box
-Fixed rear sprayer not working (what a goose chase)
-Added the Corolla rear cupholders:
Click Here to learn more
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
