Originally Posted by TN4Runnin
Hey man, I too have an 04 I did the headlight swap and 06 TRD grille with. I see in this post you mentioned using a strong hanger as a replacement hood latch/hook.
Would you care to elaborate on this solution you came up with? I’d love to be able to do the same with mine for piece of mind.
Thanks and cheers on the thread
I used a hanger with a coating on it, for two reasons. It was the only one with the same thickness as OEM rod and also prevents rust/corrosion... Took a little bit of tinkering to get the right bends but this has been working for months without failure. I hope these pictures help with your build!
2004 Sport Edition v6 4wd, 180k+ miles
My Build Thread:
CBR's Build Thread
My Write-ups:
How to Manually Release Rear Hatch with Pictures
