Originally Posted by Boreas
Well, I hope passing on this incident will help non-start troubleshooting. Don't just check your battery connections, but check all high-draw connections.
#1 rule in electronical troubleshooting is check all connections and fuses. Did you find the cause of your non starting issue?
#2 rule of troubleshooting if you messed with it start where you changed or added things.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
