View Single Post
Old 08-28-2023, 01:45 PM
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
Originally Posted by jhuerta22 View Post
Okay, so my Trail is KDSS and I noticed that you mentioned strapping the pistons. Is that while installing the new shocks?
So there is a lean with KDSS that I'll have to take into consideration. Do I need to buy a shim kit and where would I find an 1/8" trim packer? Would it be better to do that on the rear?
I'll probably go .85 up front and stock in the rear. I'm not a big fan of the rake and would like a more leveled lift. I did buy a set of 1/2" fronts spacers in case I want more lift in the front to level. I think if I go with the 1" coils in the rear I'll get new front coils to level.
Yes, I did strap pistons only while installing new shocks, not necessary to do, but it gave me peace of mind.
I made the right spacer on the front thicker by 1/8 of the inch (1/2" spacers on the front left and 5/8” spacer on the front right) to compensate for possible lean, I believe it made a difference since I have no lean, but considering that it is only 1/8" difference, if removed and in the worst case scenario I would have 1/4" lean… which is nothing anyway.
As I mentioned, I had the luxury to have a machinist at the place I work that was willing to do a favor for me and make custom spacers.
But you can find those spacers as well, see links below.
OME 0.4" Rear Lift/Lean Correction Spacer - 2003+ Toyota 4Runner / FJ (150PR10) | TheYotaGarage
Sagging Leaning 4Runners correction kits
If you go .85 up front and stock in the rear, then I would not worry about any lean spacers.
At the worst, you can always get one of those lean spacers for the rear at any point after the lift.
2013 Silver Trail (with KDSS)-Toyo Open Country A/T III, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
