Originally Posted by mtbtim
Huh? What do you mean it's the front fender that Charlie clarified? Maybe you missed my comment. I identified for the OP that the damaged connector goes to the ADD actuator on the front differential. Charlie confirmed what I said. What Charlie said is it's NOT one of the connectors for the vacuum switching valves on the driver side fender well.
The ECU coolant temp sensor DOES come off the passenger side of the engine wiring harness, not the driver side.
Dude, what have you been smoking? Let me know because I'd like some so I could do some hallucinating as well.
Why do you do that? My original comment was the wrong connector. I said I was wrong and that Charlie had the correct part of the harness...
I been smoking nothing I am glad to see its been corrected. I was just trying to help a user and I immediately contacted him saying I was wrong. I even offered to if i had the connector to send it to him so he can fix his harness..
There is no reason to act like this when people are wrong.
As you missing the purpose of being here. Its to help people fix their rigs.
You are wrong at times, and that happens. I do didn't appreciate the comment at all that I am smoking something. Your not funny when you do this as you may think you are. As you see Charlie corrected the mistake that I made. Apparenetly TheDurk missed it to.
Please don't go on some tangent trying to justify yourself. I will delete my comments on this thread that not accurate. This way it will be accurate leaving this thread cleaner. Thus Correcting it.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
