For Future readers:
I found the harness piece I thought I had. I read these off the connectors as every connector first numbers are always 90980 -xxxxx
The female connector on the actuator switch part number 90980-11250
The second male connector up from the actuator switch part number 90980-11155
The connector off the main harness that Tim identified and phattyduck verified part number 90980-11156.
For the wire connectors pigtails, I add the Wire Harness Repair manual [RM1022E]
Hopefully, this will help others down the road..
I am also seeing another issue..tapatalk is leaving out comments or not always loading things. I never saw TheDurks additional comments on this thread until now with part numbers...Interesting.. Very interesting indeed. Unless the forum is not indexing correctly. Who knows. :-)
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
