The simplest way I found out to get a stripped 10mm Alan hex plug out is to use a t55 torx impact bit. Hammer it in, and the plug will come out. After a replace the plug , I cover the head in mp grease so I never have issues again.
I am looking for the replacement aluminum crush washers in all these diff plugs in copper as if they are flat and the proper dimensions. You can reuse them forever. As both copper and aluminum flats are perfect for reuse. I don't care for the single use washers myself. Seems wasteful to me.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
