its great on the highway. its great off road WITH DRKDSS switch and upgraded brackets. 10/10 would recommend. we kept up with stock gen2 raptors in baja. sway bar was not the limiting factor.
if youre going fast on dirt roads you will get to the point where you want the sway bar turned back on anyways. the switch from drkdss allows this.
