Originally Posted by xtremewlr
Sounds like part # 2327350040 - HOSE, FUEL, NO.2
23273C in the diagram here:
I think it's a return line that comes off the passenger side fuel rail, running behind the intake manifold. Not cheap at around $150, depending where you buy it. But it's a fuel line and you DO want to replace it if it's leaking.
It's the hose with the white clip in this pic of my engine.
Yup, that's the hose! i thought it must be some type of return since it just had hose clamps and would've been at a lower pressure perhaps. The leak was at the connection of clamp 23273D (there's two of these clamps). Since 23273C is a hose, I'm hoping the leak point is it versus the metal tubing of 23803B. Buying a replacement. Thank you!!!
