View Single Post
Old 02-03-2024, 07:41 AM
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Originally Posted by lj4r View Post
leak is coming from the left side cv axle seal where the axle inserts into the differential case. Transfer case is dry as a bone. Rear differential is dry, transmission and motor are dry. Phil
That's the same side they put the axle on right. The leak was there before replacement and it's still leaking or did the leak come after axle replacement. Either way you mentioned they installed a new dust seal also. Unless someone has taken your axle off and put a die grinder in the seals seat why would the case be bad. What was their explanation why the case is bad. If they actually did install a new dust seal they did it incorrectly or knocked it out of its proper position slamming in the new axle wrong. I would never let a"mechanic" work on my truck!! If I had to I would be all up in their grill watching every move haha 😆
Jakeepoo3 is offline   Reply With QuoteReply With Quote
