Originally Posted by Busbd
Per the above suggestion to use the threaded holes. Thanks for the suggestion. My limited does not have those threaded bolts, just unthreaded holes used to adjust the parking brakes. Wish I’d had the option to use the threaded holes.
Did you look in the right place? The threaded holes are on the outside of the center dome part of the disk. They are relatively small, about 8mm. I have never seen a disk without them.
