Originally Posted by GrimJeeper91
I did my first oil change on my '24 last weekend. Replaced the factory plug with the ValvoMax. First off I discovered that my plug was installed without a crush washer. Also, the factory plug was not magnetic. I'm not worried about not having a magnetic plug, particularly since you can lay eyes on the filter since it's not hidden in a metal can. I also clean my catch pan after every oil change so I can see what, if anything, is coming out of whatever is being drained.. The Valvomax is the first drain device I've ever used so I can't really comment on it yet. In theory I like it but time will tell. I'm not worried about it being SS since you install it once and leave it. It also comes with a crush washer.
I'd be willing to bet the drain plug gasket installed at the factory was stuck to the oil pan. So likely you now have two drain plug gaskets stacked, which will probably start to seep.
