Originally Posted by paczowski123
If i remember correctly the shank on the bolt is longer not the threads, so removing the bolt and cutting down would just remove the top threaded section. If I cannot locate the correct thread pitch/length I may be just removing it and taking it to a hardware store.
You can match the bolts/diameter/threads, etc. just make sure you get grade 8 bolts.
