Originally Posted by stephan07
2017 TRD Pro. Car starts in park. Light says P and N when shifted. Blank in all others. ABS and check engine lights on. When driving, it slips into neutral, revs. I'll adjust the shifter a few times and goes back in. Its not my daily, but getting worse.
48k miles on her. I'm gonna try and swap out the safety switch, but it looks like a real mutha F er to get off.
Anyone got any hints on the getting the switch off. Ive been on youtube, and all struggle. Someone used a plumbers removal tool with decent success.
150$ and a lot of F bombs to do it myself, or 850 at the dealer... I'm gonna give it a go.
you should not adjust switch, there is no adjustment to it, not inside nor outside. hopefully you get it back properly. as of removing switch, here is the tip: wire brush on drill polish all rust from tip of shaft protruding from switch, then us PB for couple of hours. last resort to cut switch with oscillating blade, but it is danger to damage shaft. anyway, I do not know your abilities, but applying excessive force is damaging to shaft.
