Originally Posted by Jetboy
My take is that the TRD Pro fox are the best option there is for most people. Myself included. I could not find a set resonably priced for my Tundra or that's what I'd be using. They're still $5k for the set for a Tundra. For a stock truck running 32" michelin street tires that I use for towing my toys around - hard to justify $$ for suspension. I'm currently living in Alaska and the trails are not very good for full size vehicles. I almost always use my side by side. Even it is often too big/heavy for getting around on soft muskeg stuff we have (think driving on peat moss bogs). My tundra would become a submarine. However, if I could find a used set for $1500 like I see from time to time for the 4Runner, that's what I'd go with. There's no way to get a 2.5RR to ride as nicely as the bypass shock design does. At least not for the typical driving most people would do with a standard configuration 4Runner.
I think you'd be downgrading from the TRD Pro fox to a 2.5RR unless you're planning to regularly use it something close to actual desert racing or you need a lift that is higher than you can do on the Pro fox setup or something like that. The TRD Pro fox setup is pretty close to what I'd design if I had a clean sheet and the resources of Toyota. The 2.5RR is an off-the-shelf component set assembled for a 4Runner vs a bespoke design just for that vehicle.
I thought the 2.5s were good. Excellent on fast desert roads. Good but a bit harsh on the highway. If I were re-tuning them I would soften the compression damping about 20%, maybe more. The tundra 2.0 feel much softer. Oddly - I would say the front on the Tundra is significantly softer than the rear in the Tundra 2.0s. The rear 2.0 tundra shocks give you a LOT of damping all at once when you hit big bumps fast. I don't like it very much in that situation. Enough that on things like speed bumps I wince a little when the rear end hits. It feels like I'm bottoming out on the bumps. But I don't have rubber bumps - I have air bags. I'm pretty sure I'm not bottoming out. But it feels like that harsh impact at times. Slower speed - feels super soft.
The only shocks I'd look at as an upgrade from the TRD Pro would be maybe the BP51s, or 8100 bilstein setup.
Agree with you that the TRDs are likely the best single solution for most folks, given all the considerations I have (ride, height, rebuildability), they certainly are for me.
Appreciate the rundown and analysis! Great to hear some different perspectives.
Now to go list my 1 year old Fox 2.0s...
