Originally Posted by mendozer
you lost me on that. the camera has an RCA for the head unit and a black/white power wire plug/wire pair. I was thinking that since I have to run the RCA all the way to the head unit, and it's powered by the ignition, why not run that power cable (red i assume) to the head unit's power cable? it would be on whenever the head units on. Black i assume would be to the cars negative or ground.
i don't know what you mean by trigger wire
The head unit will have a trigger wire that lets it know the vehicle is in reverse. Camera has power/ground/RCA. Head unit has RCA and trigger wire. Connect the camera to switched power (that is on with the vehicle) and connect the head unit trigger wire to reverse lights to automatically switch to the rear camera signal when in reverse.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
