let's start with the obvious question; do you have a pedal commander or anything like that, have you done any mods where you've tapped into break line or fuses. do you have a remote start?
the brake AB code probably means you need a new brake switch. when you press on the brakes do your rear lights light up? intermittently? do they not come on at all. if not then you most likely need a brake switch . it is not a difficult DIY. I would maybe start there and move from code to code
Gracie, rest in paradise big girl, you never gave up. Until we meet again at the Rainbow Bridge
