Originally Posted by rpm5099
Based on your description that had to be the problem. I'm glad it worked out. Funny that you took out the resistor for the repair, you lacked faith!
I just used mine in the first hot weather and no question 20kohm is not enough. I'm going to install a variable resistor and adjust pedantically like a nut until I get the exact value for maximum cooling with no freezing. I've gone this far, might as well.
Onwon 20K Ohm Resistor 10 Turn Potentiometer 2W Wirewound Multi-Turn Adjustable Precision Potentiometer with 10 Turn Counting Dial Rotary Knob 6mm Shaft (20K Ohm) https://a.co/d/gh9Q00Q
I’m hoping you could provide some info on where exactly to install this resistor. Is it as simple as cutting one of the two wires and putting this in line?
