let me see if I can help. this is my thought process here...
- stand right next to the door. as close as you can. does the car unlock or respond when close but not when far? If yes, it's likely the antenna/amplifier . if no it's either the antenna / amplifier or a bad key. move to step 2
- the only way to rule out a bad first key is to program the second key. if it works, then your ECU/antennas are fine. if it doesn't then it's the ECU or antennas and we can move to the next step
- the antenna/amplifier/ receiver is more likely cause than the ECU. has anyone actually had an ECU go bad? probably Im sure but I don't see it often
Gracie, rest in paradise big girl, you never gave up. Until we meet again at the Rainbow Bridge
