View Single Post
Old 12-16-2025, 11:52 AM
Humble Leader's Avatar
Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold
Originally Posted by 61hawk View Post
Thanks, no third row seats or sliding tray. The receiver came in today and I was able to take the cover off and look at the circuit board... it looks good, so we'll see.
Do you know if I have to reprogram the key (open door, put key in ignition 3x, etc...) or should this be a plug and play thing?
its not plug and play because the computer needs to recognize the new receiver. there is a series of unlock/locks you need to do if you don't have the push button start. you can try it yourself and if that doesn't work you will have to go to the dealer. the good thing is programming a new receiver should be cheaper than a new remote. I would try this sequence below, I have a push button so I don't know if this works or not or if doing the above incorrectly will further impact the fob use. but doesn't hurt to try:
1. drivers door open and unlocked. all other doors closed
2. key in / out. insert and then immediately remove
3. within 5 seconds press drivers door lock/ unlock switch in this sequence: lock,unlock,lock,unlock,lock,unlock
4. key in /out again
5. within 5 seconds repeat step 3
6. insert key
7. IGN on but don't start engine, then back to lock
the door locks should cycle lock then unlock to indicate the vehicle is in programming mode
within 40 seconds of that press lock and unlock on fob together for 1.5 seconds to 2 seconds the release
then press lock button for about 1 second
the door locks should cycle again. once means success twice means try step 2 again
to exit remove the key the doors will cycle lock then unlock to confirm you've left programming mode. test the fob
Gracie, rest in paradise big girl, you never gave up. Until we meet again at the Rainbow Bridge
